the bad luck streak continues!
first someone smashes my windshield now i may have to replace my transmission [:@](anyone have any idea how much that costs btw? im sure a lot of a lot)
anyway if i do replace it im getting a new clutch while im at it since mine was starting to go anyway. id like to get a stage III (dont know what company to go with) or possibly an s4 or rs4 clutch from ecsbut i dont know if ill be able todue to money issues. any suggestions orother recommendations?
RE: the bad luck streak continues!
You can re-build a manual trans, its just hard finding a certified tech to do it. There may be only 50 peoplein the US that are capable, so call the dealer if they have someone that can.
It would cost around 15 hours to take it out and build it, and around $300 for the re-build kit.
they place i took it to said that it would most likely have to be replaced (but ill see if i can find out for sure)because thecasing cracked and someteeth on the gearsare broken... ya know,all that fun stuff.. not really sure how it happened either. the car just decided it didnt want to move anymore
If the crack isn't big it can easilly be tig welded by someone that knows how to weld on aluminum,
as long as its not across the bottom of the tranny.
All in all it might end up in more labor than the tranny is worth, you might wanny try www.shokan.com for a used tranny then buying a clutch for it. It all depends on the damage and if you can find someone to do the work.
my guess is its probably on the bottom. ill try shokan and see what they have but theguy who is going to replace it said he would look for a used one. just out of curiosity would i be ableput a6-speed in instead/would it cost more?
ORIGINAL: Lebe Frei
I had to replace the cvt transmission on my 2003 A4 a few months ago. The guys at my Audi dealership quoted me US $11,000 to do the job. Since that pricetag wasn't an option, I found a good import mechanic who did the job for the low, low price of $6,500. Much better price, but still a jaw-dropper.
BTW,my car only had 60K miles, received allregularly scheduled maintenance work by the dealership, and used only high grade gasoline.
Disappointing.
Bad Justin
09-29-2008 12:45 AM
