back firing?
back firing?
hey i owe a 2004 a4 with evo intake and magnaflow exhaust. my problem is wen iam using the tiptronic and are in like 5 or 6th gear and floor it my car kinda hesitates and sounds like it back fires and ideas why or whats wrong?
RE: back firing?
have you tried using any injection cleaner? I had a similar problem on a 2.5tdi and it was doing also doing it in the upper rev range. poured the injection cleaner in and the problem has been solved.
Hope that helps.
Hope that helps.
RE: back firing?
Check for a leak on your system between from airfilter to turbo. if there is a leak, you will deff. run rich.
you can use seafoam to clean your injectors. you can find it in any auto store.
