Sponsored by:
Sponsored by:
B7 time slip database
Old 03-10-2006, 07:21 PM
2871relimB5A4's Avatar
Default RE: B7 time slip database
cool. i cant wait to see tese things with bigger turbos.
Old 03-10-2006, 07:31 PM
audiboy1618's Avatar
b7s weigh about what the b5s do. And for the record, a ko4 does not flow near enough air to run 12s.
Old 03-10-2006, 07:33 PM
18T's Avatar
18T
18T is offline
holy shiznit! orgasmic numbers
Old 03-10-2006, 07:51 PM
PandaXpress's Avatar
ORIGINAL: audiboy1618
actually no
from audi usa
2006 AUDI 2.0T
Curb weight (lbs.):
multitronic, FrontTrak: 3450
manual, FrontTrak: 3428
manual, quattro: 3549
Tiptronic, quattro: 3660
Old 03-10-2006, 07:54 PM
Oh my bad, thanks for the corection cheng.
Old 03-10-2006, 07:55 PM
InsaneHatter's Avatar
yea I thought b7s were much heavier than b5's...
yea... i dont know what boost levels 2.0T's run but im sure a k04 could get you into the mid-low 13's... im sure if APR comes out w/ a strage 3 w/ the 28R that would be into the 12s
Old 03-10-2006, 07:59 PM
Most likly. A gt28r can flow 320hp. But my guess is Apr will develop a big turbo using the gt28rs and run lower boost levels. The only reason Apr used a gt28r for the normal stage 3 kit was for drivibilty, it spools really fast. Now that the 2.0t is bigger, they will def use a gt28rs, has so much more potentiol, it can flow more along the lines of 400hp.
  #18
Old 03-10-2006, 08:01 PM
yea, the 28RS and the 2.0L block are a good match.. not just for audis.. I know someone going to a 28RS on his Mazda Speed Protoge... thats a 2.0L block as well... it seems to spool real nice with a 2l and 28rs
  #19
Old 03-10-2006, 08:18 PM
liquidxit2's Avatar
I think a b7 chipped is as far as I would ever go. If b5s wiegh 3200 pounds then why do they run high 15s when compared to a similar powered and heavier weighted dsm (210/214 torque) runs 14.8-9. Or am I totally off the bench racing? I got the dsm times from my dsm stock.
  #20
Old 03-10-2006, 08:46 PM
Thats not rocket science. Differnt motors have differnt characteristics. The 2.0t power band is different from the 2.0t powerband. Instead of the famous 1.8t falling on its face at 5500rpms, the 2.0t keeps pullings. The 6sp makes a BIG differnence, gearing alone can drop .5 of a et. The clutch setup is different on the 2.0t, its stronger and has more clamping force for a harder launch, like i said, its not rocket science.
Quick Reply: B7 time slip database
