B5 facelift, increasing remote range
RE: B5 facelift, increasing remote range
ORIGINAL: Lazer Viking
yea, i knew what it was, its just a pain in the *** to turn it off every time i get out
I've got a 98. I found a wire that looks similar to the one in the pictures in the link but when I openned it up i found 4 wires, 2 brown, 1 purple and 1 green with a yellow stripe. Did I not find the correct wire?
ORIGINAL: a88fl1
#18
just did this mod, and it took me no more than 10 minutes.
the hardest part was figuring out that the damn antenna wire is actually attached to something up there in the bumper, and realizing that I had to cut it! I now have at least 40 feet of range (that's as far as I went anyway), I'm very pleased with the results.
I motion for the original thread to be moved to the DIY section. or at least 2K S4's original post in that thread should be moved to the DIY area. thanks again 2K S4!
#19
You think it matters if you use a thicker wire than 22g? I used something closer to 18g... not sure exactly. Definitely thicker than the original remote wire...
I didn't solder, either... but I did intertwine them many times, and wrapped it tightly with electrical tape.
My range is improved a bit... but not drastically.
#20
ORIGINAL: headshok2002
how long a piece of wire did you use?
