B5 Dual Exhaust?
RE: B5 Dual Exhaust?
Yes you can but its rather a tight fit to do it.
You have to go inbetween the Evap equipment and spare wheel space to
the othe side, you will have to put a body kit that has cut outs for
the pipe to look nice
But it can be done
But it can be done
Magnaflow has muffler that has a single inlet and double outlet or you cna go
with 1 single inlet and 1 output and stack then above each other where the resonator
goes there is a Shop that has done this in Toronto it realy looks sick from under the car
if you were to lose power... it'd be like .2, but that would only be from the branch off. you'd also gain HP from the new muffler... so where you'd be normally making an extra say... 10-15HP, now ur only making 9.8-14.8 extra. I say.. go for it, if you can find someone to do it, it would be a very unique mod. you're not gonna gain any extra from it being dual (which is why most people go dual) because you'll basically just be running off another pipe from an existing pipe, and like AB says, that run off pipe will be quite tricky... or... a spiderweb... that run off pipe may end up actually being a vaccum... and you could lose .2HP... not only that, but if you live in a cold area... one of hte pipes will be pouring out much more smoke than the other pipe. which is very rice.
