B5 Door Panel
Old 10-24-2005 | 03:13 PM
TripN's Avatar
Default B5 Door Panel
Anyone know how to remove the door panel on a 2001 A4? My rear window is stuck and I wanted to check to see what was wrong. I found 3 screws and unscrewed them but the panel was still not coming off.
I wonder if the regulator is bad....dealership said $350 to change the regulator.
Old 10-24-2005 | 03:53 PM
Jestnomen's Avatar
6th Gear
Old 10-25-2005 | 06:35 PM
Tlag's Avatar
Default RE: B5 Door Panel
I have already downloaded your post on taking the door apart. Great info, thanks.
I have an A4 T1.8 1999.5. The left rear window won't stay up. Using the switch, while someone pushes up on the glass, will get it closed, but it won't stay. I assume it is a window regulator I need. Let me know if you think I'm off base on that. From what I have seen, there is not too much difference in price between a motor and regulator, and just the regularor. Can you suggest some sources? Would you recommend getting the regulator with a motor or just a regulator? Are aftermarket regulators ok. Thanks for any help you can offer.
Old 10-25-2005 | 07:00 PM
Jestnomen's Avatar
6th Gear
Check this link out...
http://forums.audiworld.com/a4/msgs/2355923.phtml
audi guru
06-06-2013 05:39 PM
dkazimee
01-14-2008 10:31 AM
Buttery Cracker
12-26-2007 10:20 PM
Buttery Cracker
12-12-2006 02:59 AM
b52000a4
11-14-2006 10:26 PM
