B5 2.8 overheating
B5 2.8 overheating
Hi, I am new here and i have a 96' 2.8Q with an overheating issue.....the coolant level is fine and as far as i can tell the fan is working properly. Any help would be greatly appreitiated....
RE: B5 2.8 overheating
It may not be holding pressure, check the lines for any moisture at the connections, the coolant level may look fine but it'll leak very slowly. Maybe your water pump is bad or the thermo is stuck closed not allowing coolant to flow, or a faulty temp sensor just messing with the gauge reading.
