AWE Stage 3 Clutch Kit
Old 11-06-2007 | 12:45 PM
Flip's Avatar
Default AWE Stage 3 Clutch Kit
Is anyone using the AWE Tuning Stage 3 Clutch and flywheel? How is the pressure and would you recommend it over a different setup? If not please post the setup you prefer. Thanks
Old 11-06-2007 | 01:54 PM
chaos92287's Avatar
Default RE: AWE Stage 3 Clutch Kit
the AWE kits just look like southbend kits
AWE
My southbend stage 5
so whoever is cheaper, i would go with. i have a stage 5 southbend and absolutely love it. pedal pressure is harder than stock and it releases at the floor compared to towards the ceiling with the stock clutch, but its nothing unbearable (im 5'7" 140 lbs and have no problems using it as a DD in Tally, which takes 20 min to go half a mile) and i definitely prefer it over the stock clutch. engagement is so much more solid
Old 11-06-2007 | 05:48 PM
Fier Ringe's Avatar
Default SouthBend Clutch
I would get a Southbend clutch but you can get either one from: www.avalonmotorsports.com
Old 11-06-2007 | 06:21 PM
Flip's Avatar
Default RE: SouthBend Clutch
What is the clutch rated at on the southbend kit?
Old 11-06-2007 | 06:34 PM
chaos92287's Avatar
southbend stage 2 is rated at 290 ft lbs and costs 390
southbend stage 3 is rated at 300 ft lbs and costs 450
stage 4 is rated at 450 ft lbs and costs 585
stage 5 rated at 576 ft lbs and costs 650
18lb lwfw from southbend is 475, but i got mine for a little over 300 and its an 11lb flywheel
Old 11-06-2007 | 06:37 PM
Flip's Avatar
I checked out the southbend kits but they weren't very clear. Is the flywheel included in the kit? I assume it's not since the price is so low.
Old 11-06-2007 | 06:43 PM
chaos92287's Avatar
the AWE stage 3 clutch has a kevlar lining and is rated at 400 ft lbs, but with southbend they use a kevlar lining on their stage 2 clutch (only rated at 290 ft lbs) and then upgrade to Feramic on their stage 3,4, and 5. and the pic they use on their site (the one i put above) looks identical to the stage 2 clutch from southbend
here's a pic of the stage 2 clutch from southbend
it jus raised a few flags in my head, might wana contact AWE and see what the deal is
Old 11-06-2007 | 06:44 PM
chaos92287's Avatar
ORIGINAL: Flip
nope, flywheel not included
Simon0605
07-19-2008 03:51 AM
skatemerica155
03-28-2008 08:46 PM
brent07
01-23-2006 05:39 AM
Quick Reply: AWE Stage 3 Clutch Kit
