AWE Drive Train Stabilizer or APR snub mount
Do these two parts perform the same job? The AWE stabilizer is quite a bit more expensive than APR's snub mount however the AWE would be a much easier install. The only thing I'm trying to get rid of is the incredible jolt I feel when shifting from 1st to 2nd during WOT.
RE: AWE Drive Train Stabilizer or APR snub mount
they almost do the same thing. you can get a snub from greedspeed for $15 and it is the same as apr. the install is not that hard for the snub it just takes some time. the snub will cut down on the jolt. with the addition of a dts it will make nice crisp shifts.
ORIGINAL: hb972.8q
Are you saying that doing both would be beneficial, or was that a comparison of the benefits of each option?
ORIGINAL: mathas
Just to clarify (for the newbs like myself), you first say that the snub mount and DTS do almost the same thing. Then you talk about the snub mount and say "with the addition of a dts..."
ORIGINAL: hb972.8q
the dts is attached to the tranny to the frame of the car and that holds the tranny from any movement.
eather one is good but both would be nice (someone buy me a dts).
if you want to go farther into it you can replace your tranny mounts with modified allroad ones. this just takes it one more step. most people dont have or know about this mod.
isnt the dts like 250 buks? opposed to the other thing which is 15? seems that if ur gonna spend the money, just buy both, and install when convienent, its not causing any damage or anything
I had the GreedSpeed snub mount installed. It is a noticeable difference compared to the warn out stock mount, but there is a still a minor hint of movement.
The snub mounts from APR and Pure MotorSport are not the same as the GreedSpeed. I was wondering if these (over the GS snub mount) would take out the remaining movement, but I have my doubts. I also wonder if the other motor mounts are fine. I'll probably swap them out before considering the AWE DTS.
The AWE DTS should take out ALL drivetrain movement I'm guessing, but a hefty price. And I'd expect it to get scraped on lowered cars.
The GreedSpeed snub mount is good for the money, its suppose to be an old VW Fox snub mount, but I couldn't find the VW part number so I got it from GreedSpeed.
