AWD vs 4x4
RE: AWD vs 4x4
well unless you've got lockers on your 4x4 then you only have 1 wheel putting power to the ground in the back and 1 in the front while in 4x4. with lockers then all 4 are engaged. 4x4 is also ment for lower speeds...use it on the highway and chances are something is going to give out.
RE: AWD vs 4x4
yea sorta, you can use it at speeds in slipery conditions, just not on anything grippy... AWDs like ours have a center differential that takes the place of like the transfercase in a 4x4 making it so its not putting stress on anything.. With AWD you have much better control in any condition
ORIGINAL: MissionCtrl
RE: AWD vs 4x4
Emphasis on ANY condition
ORIGINAL: BadLuckAudi
RE: AWD vs 4x4
ORIGINAL: Lazer Viking
so give us some more ground clearance and we could own 4wheel drive trucks
https://www.audiforums.com/upfiles/3...FD6A644828.jpg
