Audi A4 Heat Problem Not Blowing Hot! Please help!
I own a 1999 Audi A4 and the heat blows warm for about 15 seconds or so when the climate control is up on "HI"(So as high as it can go)and then it goes back cool again even though I didn't change the temperature. What can cause this? How do I fix it?
The air works awesome and blows super cold. Please help! Thanks everyone.
RE: Audi A4 Heat Problem Not Blowing Hot! Please help!
don't panic, the temperature is adjusted automatically by the climate control -Unless your freezing your nuts off in the cold and it don't heat up.
Turn the temp up alot higher and see if it stays hot for longer.
