audi a4 1.9 tdi starting problems
I've got a A4 B5 1996 1.9 TDI
The problem is as follows
When I try and start the car from cold it wont start, if I use quick start in the air intake it starts no problem and then will continue to start eventually (about 20 seconds) until I leave it over night again.
I have had all the electrical side checked out at a garage, the glow plugs have been replaced and the relays checked and they are all working fine.
has anybody got any suggestions that I can try before it has to go to a diesel specialist, keeping my fingers crossed it's not the diesel pump as it would probably be as cheap to replace the car.
thanks in advance for any help you can give me.
RE: Audi a4 1.9 tdi starting problems
possible causes are coolant temp sensor/fuel leak and air getting into the system/fuel filter,
a common problem because of its age is the braided pipes that connect to each injector for lubrication the pipes rott and diesel can easily be seen all over them
