Sponsored by:
Sponsored by:
ATW Head.. need advice..
Old 02-22-2007, 01:35 PM
JohnnyBravoA4's Avatar
Default ATW Head.. need advice..
Need some advice on what i should offer a audizine member for this Head.. it has 66k on it, on car-parts.com they sell for 350-1k, i found a few rebuild heads for $850 plus a core (core charge 250).. he said make an offer and i really dont know where to start.. here are a few pics, take a look tell me what you think of the head and what a good first offer might be.. thanks..
[IMG]http://i133.photobucket.com/albums/q53/SchnellMotorsports/Picture016.jpg[/imgae]
Old 02-22-2007, 01:40 PM
lakesailor's Avatar
Default RE: ATW Head.. need advice..
Does "ATW" head mean it's an aftermarket head?
I would suggest having it fluxed to check for cracks, and don't forget it will need to be decked by a machine shop before you can install it. I'd say nail down what exactly you think he payed and then offer about 60% of that and see what he says.
EDIT: but if it's a stock head, I would just offer $450-$500 if a lot of rebuilds go for $850.
Old 02-22-2007, 01:44 PM
its off his car.. he went with an AEB head.. ATW is the engine code for a 2000 a4.. atw has smaller ports than the AEB.. I dont know what he paid for his head.. AEB heads are cheeper ATW heads are hard to find and are a one year engine code.. what do you think a machine shop with charge for all that.. and i dont know if anyone knows if the ATW head can be ported?
Old 02-22-2007, 01:48 PM
lakesailor's Avatar
I wouldn't buy a used head unless it's been fluxed to check for cracks, especially on a turbo car. As for pricing on decking and fluxing I don't really know, all the work I've ever had done was done by a friend of mine for no charge.
And you might as well port it and give it a three angle valve job while you've got it off.
Old 02-22-2007, 01:55 PM
so basically might just be better to take mine off and have it machined and fix the valves that are bad.. would save me cash in the long run.. i just figurned i could clean it up and slap it on
Old 02-22-2007, 02:05 PM
lakesailor's Avatar
What do mean my "bad" valves? Are the valve seats worn?
Old 02-22-2007, 02:07 PM
I dont really know i failed a leakdown on cylender 2 at 30% on the intake side.. so i have a bad intake valve i guess the seats warn, but i have not taken the head apart to look at it..
Old 02-22-2007, 02:11 PM
lakesailor's Avatar
Is your car a daily driver and you're trying to avoid down time?
If you're able to take the downtime, I suggest pulling the head off and take it to a machine shop. Have then magnaflux it to check for cracks. Then have them do a three angle valve grind and slap some new valves in it. Last but not least, it will need to be decked (machined flat).
Then you'll have basically a brand new head.
You absolutely cannot take a head off and reinstall it without it being decked.
Old 02-22-2007, 02:19 PM
you right.. i can drive another car.. the car was sold to me like that from a dushbag forum member.. he knew it had a valve problem and didnt tell me, car had never really run right.. but it is a stage3+ car.. just has so many problems.. i kinda got screwed.. i wouldnt by another car off the forums again thats for sure
Old 02-22-2007, 02:30 PM
wood_e's Avatar
I'd give him 300 for it. You can have it cleaned up and it will probably be fine.
Quick Reply: ATW Head.. need advice..
