ATP GT2X VS GT28RS TURBO SETUP
#101
RE: ABT GT2X TURBO SETUP
I am running an ATP kit, currently 322bhp (crank) on a 4wd A4 1.8T. Custom map which still needs some work but I don't believe a K04 would get within 80bhp of that...?
For me the K04 is a great mod if you don't want to get some serious work done (I had a K04 before my GT28RS) bit the 28RS is just soooooo good.
Greg
Greg
#102
Well a full 28rs is def going to be a whole dif ball game. And yeah, a ko4 can come within 80hp of that easily. Ive seen one ko4 gragh(mmart) making 274hp, which is 48hp shy, and alot less power band, go bt
#104
I'm sorry, what I was saying was that I believe that at 18 psi, with their mika software and injectors and a catdelete pipe, I can make close to 250whp. Maybe not quite that much, but close. The reason I can only run 13 psi is because I only have stg II software. Oh, Yuikio, my gt28r was converted to a gt28rs eliminator. The only difference is the turbine housing. The original meets up to a t25/t28 flange , can't remember right now which, and the eliminator bolts up to the stock mani, which I still have. ATP is supposedly coming out with a new one, but who knows how long that will take. Right now all I have is an adj fpr, and a remus catback.
#105
So you have a GT28RS compressor inside a GT28R housing that bolts the stock manifold? Isn't that what they call the "GTRS?" Whatever, that is an "eliminator," then. You were right. I really don't mean to be a dick, but your estimate doesn't mean all that much in terms of hard comparison numbers, but I'm happy for you for being happy with your setup. I know that the ATP GT28RS software isn't too shabby, but in my limited searching, I haven't seen someone happy with ATP software for the eliminators except for you. You should get it dyno'd so you can tell the world that your elim kit is good.
#107
Yeah, it seems like the developed that one more. They actually have some real quarter mile numbers for it, even though it's probably 28psi on 116 octane with a carbon-kevlar clutch and no interior.
