ash tray mod
RE: ash tray mod
ORIGINAL: onepoint8tee
i think it will not allow you to lock your car with the remote if the engine is still running with the turbo timer on. not sure but i read that once.
RE: ash tray mod
yeah, I thought about that too. However, I have programmed my ECU via VAG to auto lock the doors. So I'm hoping when the motor finally shuts down and there's no key in the ignition, the doors will lock in 30 secs...as it is set now.
RE: ash tray mod
ORIGINAL: RLB6
RE: ash tray mod
I have the VAG software via laptop so I can only give you instructions using this route:
in the software, I access module 35 which is the central locking module. I go directly to it using the Direct Entry field.
Click on the Recode button.
In the software code field, enter 16236 and press the enter/do it button
that's it.
I've played around with some other codes too, but code 16236 does a couple of other things too like:
Control the windows/sunroof from the remote key fob
Doors lock automatically when you go a certain speed. I think its when you exceed like 10 or 15 MPH.
that's it.
RE: ash tray mod
ORIGINAL: lauren5757
Why don't you do what i did and "mod" it into a really great coin collector?????
If you need instructions let me know.
#18
RE: ash tray mod
#19
RE: ash tray mod
ORIGINAL: RLB6
that's it.
that's it.
#20
RE: ash tray mod
Im gunna have to ask your for some detailed step by step instructions on this "ash tray mod"... Sounds a little out of my moding capabilities...
Plan on getting a rental car for about a week, you won't be able to drive your car during the duration of this mod.... and yes, it DOES take the whole week. You must be very precise and careful with each required step.... or you will be sorry. Luckily, when you eventually decide to sell your car, this mod alone will increase its value by a few K's.
