Sponsored by:
Sponsored by:
APR Programs?????
Old 09-23-2007, 01:52 AM
kolan67's Avatar
Default RE: APR Programs?????
dibs.. if cincytt or a tech says they do =]
Old 09-23-2007, 09:51 AM
turbo kraut's Avatar
Tech Guru
my bad, i didn't read the whole deal, you gotta pay 499 for prog + 500 for injectors, yeah i would do stage 1 and then do w/m instead of the +1.......... if you are going to spen a grand you might as well spend a little more and get a bigger turbo
Old 09-23-2007, 11:35 AM
cincyTT's Avatar
I'm make believe
ORIGINAL: ThePaintballGuy
If that file uses 310cc injectors I have 4 of them for sale. I am going to go post them in the classifieds. here is a link to it: https://www.audiforums.com/m_649976/.../tm.htm#649976
josh
Did you get 8 or them or are you now using a fuel pressure increase only tune now for the K04? Also if the shaft play is minimum in the turbo, clean the compressor housing to make it nice and then sell it stating you have to use your original turbine housing. Should sell for $80-100
Old 09-23-2007, 11:36 AM
cincyTT's Avatar
I'm make believe
ORIGINAL: kolan67
That fileuses 380cc injectors from a 225TT
Old 09-23-2007, 12:39 PM
Audi_Skydiver's Avatar
ORIGINAL: cincyTT
josh
Yes I did get 8 of them. I got a SICK deal on them for all 8 and figured I would use the 4 I need and then sell the others to get some money back. And I am confused as to what you are saying about the housing? I don't think anyone would buy it because there are 3 small cracks on the inside of the turbo housing on the exhaust side.
Josh
Old 09-23-2007, 12:42 PM
cincyTT's Avatar
I'm make believe
If the turbine housing (exhaust side) is the only thing bad and the shaft play is minimum, you can sell it if its clean. The will just have to swap the housing
Old 09-23-2007, 01:05 PM
Oh, ok. I see what your saying. Yeah there is nothing wrong with the other side and there is only a small amount of shaft play.
Josh
  #18
Old 09-23-2007, 01:53 PM
cincyTT's Avatar
I'm make believe
Then sell it and make a quick $80-100
  #19
Old 09-23-2007, 02:34 PM
Papachristou's Avatar
Dont use the APR injectors, you need spacers and APR seats with them and they seem to have a lot of trouble... You can get OEM tt225 BOSCH 386cc injectors like i did for about $300! there is a guy on audizine that sells them... drop me an email if u want his info but if you search a lot of people who have APR 1 then get reflashed for APR 1+ say its a lot smoother program and its like getting chipped again for the first time!
If you are really wanting power out of the k03 i would do 1+ and water/meth
at any rate its nice to actually be able to pull off from cars now and not worry about a stock civic or a minivan pulling on me!
i had to go get flashed when a toyota prius pulled on me off the line
  #20
Old 09-23-2007, 03:00 PM
cincyTT's Avatar
I'm make believe
You can get seimens 380cc injectors for $250 from usrt here. They have stock spray pattern and cost less. ALso i HIGHLY doubt that getting the 1+ is that big of a gain. Normal tune and with the money thatyou would ofspent on the injectors and the 1+ would get you a nice w/m kit and with a vagcom you can make the car way faster than a 1+ car. And if your spending money for the 1+ kit, you should of just saved up more and just got a real turbo kit.
Quick Reply: APR Programs?????
