APR options
APR options
quick question... About to get the APR stage 1+ program and wanted some advice on whether the "Fault Code Erase/Throttle Body Alignment" add-on option was necessary or suggested. I'd rather save the money but if it's important i wont skimp on 60 bucks. Thanks for any help.
RE: APR options
i don't have a vag-com... would i be better off investing in a vag-com or is neither really necessary... if all i would be using the vag-com for is those two functions i can't imagine a vag-com comparing in price to the added feature for 60 dollars.
RE: APR options
If you have a laptop, you could spend $70 for the cable and software for vag com. id hold off on that apr option and get vag com, you can do so many more things with vag than just reading/clearing codes and a tba.
RE: APR options
thanks for the advice... is there any way you could point me in the right direction for that cable?? I have a laptop so that seems to be the most reasonable thing to do. Is any liscense required for the software or would i just need the $70 cable?
