anyone install a greddy full auto tt?
Old 10-16-2007 | 07:41 PM
turbo kraut's Avatar
Tech Guru
Default anyone install a greddy full auto tt?
i spent most of the day trying to install a full auto tt into my b5 a4 and when everything was all said and done after ready like 4 diy's it still didn't work
problem is most diy's are on greddy 3's or full auto's in a b6(http://audizine.com/forum/showthread.php?t=77568) this one
also problem, i don't have a rear ashtray with heat warmer
if someone has ran a greddy full auto in a b5 can you give a brother a hand
tia
Old 10-17-2007 | 12:25 PM
cincyTT's Avatar
I'm make believe
Default RE: anyone install a greddy full auto tt?
all turbo timers you the same hookups:
constant 12v
acc 12v
ignition 12v
parking brake light.
with those 4 sources (no matter what for) your good to go.
Old 10-18-2007 | 11:35 AM
Tech Guru
ORIGINAL: cincyTT
constant 12v
acc 12v
ignition 12v
i understand those principals, but i couldn't get the unit to power up.... i used aligator clips and it still only flickered on and off.... also after doing that and putting my stuff back together windows no worky...... so i put a fuse back in the stock location even though i left the inline fuse still in the holder
and later the next day my driver side(only ds) window was acting up
any thoughts?
Old 10-18-2007 | 12:33 PM
cincyTT's Avatar
I'm make believe
connections could be bad. I would solder over clips
Old 10-18-2007 | 02:25 PM
Tech Guru
how can i solder onto the clips(plugs) sticking out of the back of the box
i am talking where the 4 prong plug connect to the back of the unit
relliMmoT
11-07-2009 08:24 AM
steezybme
04-18-2008 12:16 AM
Dj Spiel
07-26-2007 08:08 PM
jrodpikap
03-06-2007 12:26 AM
pootey
04-06-2006 03:15 AM
Quick Reply: anyone install a greddy full auto tt?
