anyone heard of this turbo??
i was looking around on the net a found this k04-15 and garrett t28 hybird i was wondering if anyone else has heard of it
http://www.mjmturbos.com/A4hybrid.htm
RE: anyone heard of this turbo??
ORIGINAL: Lazer Viking
good things cant come from combining borg warner and garret turbo's
Ok, honestly ATP makes there own housing and MJM uses a REAL ko4 housing with a real garrett chra and wheels. I think the the MTM will be a far better choice over a gt2x...bigger also. If your willing to give it a try, im sure you wont be disappointed. Will make more power than a regular ko4, gt2x and simular numbers as a gtrs with better spool time (even with it being non bb).
Also you can make get your own 225 ko4-20 turbo with a ko4-15 housing. This would bea good choice also. Should just need a larger turbo inlet and a little work to make it connect the compressor outlet.
Th t28 should make higher 200's (guessing 250-270whp)
225 compressor should make mid 200's with stock like spool (230-250whp)
ORIGINAL: kraylon
hmmm this website is MJM not MTM
what kind of programing do you use with the 225 k04-20??
Since the 225 uses 380cc @ 3bar injectors, i would use whoever's tune i have seen use that combo with a 225 maf housing.
