Sponsored by:
Sponsored by:
anyone heard of this turbo??
Old 07-30-2007, 04:35 AM
kraylon's Avatar
Default anyone heard of this turbo??
i was looking around on the net a found this k04-15 and garrett t28 hybird i was wondering if anyone else has heard of it
http://www.mjmturbos.com/A4hybrid.htm
Old 07-30-2007, 10:17 AM
Lazer Viking's Avatar
Default RE: anyone heard of this turbo??
good things cant come from combining borg warner and garret turbo's
Old 07-30-2007, 11:19 AM
kraylon's Avatar
yea i didn't think so but it sounds pretty inestering
Old 07-30-2007, 11:45 AM
pyropenguin's Avatar
I've heard of it, but the only tuning for it is MTM's software, and it's not that much more powerful than a normal k04.
Old 07-30-2007, 12:18 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: Lazer Viking
They are called eliminators..LOL
Ok, honestly ATP makes there own housing and MJM uses a REAL ko4 housing with a real garrett chra and wheels. I think the the MTM will be a far better choice over a gt2x...bigger also. If your willing to give it a try, im sure you wont be disappointed. Will make more power than a regular ko4, gt2x and simular numbers as a gtrs with better spool time (even with it being non bb).
Old 07-30-2007, 12:24 PM
cincyTT's Avatar
I'm make believe
Also you can make get your own 225 ko4-20 turbo with a ko4-15 housing. This would bea good choice also. Should just need a larger turbo inlet and a little work to make it connect the compressor outlet.
Th t28 should make higher 200's (guessing 250-270whp)
225 compressor should make mid 200's with stock like spool (230-250whp)
Old 07-31-2007, 04:24 AM
kraylon's Avatar
what kind of programing do you use with the 225 k04-20??
Old 07-31-2007, 04:25 AM
kraylon's Avatar
Ok, honestly ATP makes there own housing and MTM uses a REAL ko4 housing with a real garrett chra
hmmm this website is MJM not MTM
Old 07-31-2007, 01:18 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: kraylon
Thanks Mr. Editor sir!
Since the 225 uses 380cc @ 3bar injectors, i would use whoever's tune i have seen use that combo with a 225 maf housing.
Old 08-01-2007, 02:24 AM
kraylon's Avatar
i just thought that being MJM would make a differance from MTM since MTM is knowen and MJM is not it may be like a ebay fly by night company
Quick Reply: anyone heard of this turbo??
