Anyone ever fit B7 6 spoke wheels on a B5, and the weight?
I'm curious about two things: 1) the offset and 2) the weight.
I'm guessing 225 45 17 would do the trick for tires but there should be no rubbing correct with a B5 that has not been lowered?
And then I know the weight of the 16" B5 wheels is like 20.5 pounds I believe. Are the B7 6 spoke wheels heavier? I've seen things about Avus wheels for the S4 weighing like 28 pounds.
I'd like the change in looks of a 6 spoke wheel but could do without the change in weight if it increases. Any thoughts greatly appreciated, thanks.
not sure about offset but i just put a set of 03 a4 five spokes on my b5 looks ****. 225/45/r17 run fine and im dropped almosts 5in. previously had a set of 18x9 tsws but to big . refuse to loose ride quality for big wheels. if your at factory hieght they will look good
DerrickS
11-15-2008 11:48 AM
