ANY ONE HEAR OF THIS ADJUSTABLE NOISE BOV/ STEALTH FX/ GFB???
ANYONE TRY THIS??? HOW DID THE CAR RUN???, AND FOR HOW LONG.....
[IMG][/IMG]
By utilizing a unique air diverting system you control exactly how much air you dump to the atmosphere for noise, or the inlet for silence. By sending the vented air back to the inlet (rather than muffling it), there is no restriction and the valve still operates at maximum efficiency. For cars with sensitive air flow meters, the valve can be tuned to vent just enough air back to the inlet to prevent backfiring while giving the loudest possible blow-off noise. No more guessing which valve will work on your car - this one will do it all! Now here's the cool part … By turning the GFB world patented ratchet style head, you can finely adjust the amount of air that goes to each venting port, giving you complete control over how loud your gear changes are!
[IMG][/IMG]
RE: ANY ONE HEAR OF THIS ADJUSTABLE NOISE BOV/ STEALTH FX/ GFB???
REMEMBER WHEN I WAS ASKING ABOUT THE "CLOSED LOOP VS. OPEN LOOP"..... AND HOW I COULD MAKE THE AUDI INTO AN OPEN LOOP SYSTEM???
[sm=insomnia.gif][sm=icon_blah.gif][sm=chairshot.gif][sm=sigh.gif][sm=smiley26.gif][sm=smiley35.gif][sm=WTFsgign.gif].........Why does this get asked over and over?
I have a Spacer valve myself and even I can't believe how many times this topic comes up.
You just dont get it do you? Just because you can adjust how much boost is recirculated with that doesnt mean that its safe to use. So, if you turn it to 50% or even 90% recirc, you will only sort of be killing your engine and its components. How about you do your own searching? https://www.audiforums.com/search.asp
okay i have had enough of this shat in the last few days.. please stop talking about bov's and dv;s and open loop and closed loop.. just stfu if you would take a minute to run a simple search on the term "bov" or "dv" you would find all of these answers, on a stock audi system you must have 100 % of that waste air recirculated
and for god sakes just listen to onepoint about this... he is a fcucking moderator for a reason...
to reiterate...
100% recirc only
to reiterate...
100% recirc only
