Sponsored by:
Sponsored by:
ANY ONE HEAR OF THIS ADJUSTABLE NOISE BOV/ STEALTH FX/ GFB???
Old 03-15-2007, 10:29 PM
JETSPEED333's Avatar
SoCal Crew Member
Default ANY ONE HEAR OF THIS ADJUSTABLE NOISE BOV/ STEALTH FX/ GFB???
ANYONE TRY THIS??? HOW DID THE CAR RUN???, AND FOR HOW LONG.....
[IMG][/IMG]
By utilizing a unique air diverting system you control exactly how much air you dump to the atmosphere for noise, or the inlet for silence. By sending the vented air back to the inlet (rather than muffling it), there is no restriction and the valve still operates at maximum efficiency. For cars with sensitive air flow meters, the valve can be tuned to vent just enough air back to the inlet to prevent backfiring while giving the loudest possible blow-off noise. No more guessing which valve will work on your car - this one will do it all! Now here's the cool part … By turning the GFB world patented ratchet style head, you can finely adjust the amount of air that goes to each venting port, giving you complete control over how loud your gear changes are!
Old 03-15-2007, 10:34 PM
onepoint8tee's Avatar
Default RE: ANY ONE HEAR OF THIS ADJUSTABLE NOISE BOV/ STEALTH FX/ GFB???
Try a search every once in a while, this topic has been discussed several times. Other than that, all Im going to say is, suit up andget ready....
Old 03-15-2007, 10:41 PM
SoCal Crew Member
REMEMBER WHEN I WAS ASKING ABOUT THE "CLOSED LOOP VS. OPEN LOOP"..... AND HOW I COULD MAKE THE AUDI INTO AN OPEN LOOP SYSTEM???
Old 03-15-2007, 10:47 PM
Yup, what have you accomplished with that idea so far?
Old 03-15-2007, 10:49 PM
SoCal Crew Member
why didn't you mention this type of gfb? and how about a link to my search...
miked's Avatar
Stop yelling.
Old 03-15-2007, 10:52 PM
evoic's Avatar
[sm=insomnia.gif][sm=icon_blah.gif][sm=chairshot.gif][sm=sigh.gif][sm=smiley26.gif][sm=smiley35.gif][sm=WTFsgign.gif].........Why does this get asked over and over?
I have a Spacer valve myself and even I can't believe how many times this topic comes up.
You just dont get it do you? Just because you can adjust how much boost is recirculated with that doesnt mean that its safe to use. So, if you turn it to 50% or even 90% recirc, you will only sort of be killing your engine and its components. How about you do your own searching? https://www.audiforums.com/search.asp
Old 03-15-2007, 10:56 PM
Lazer Viking's Avatar
okay i have had enough of this shat in the last few days.. please stop talking about bov's and dv;s and open loop and closed loop.. just stfu if you would take a minute to run a simple search on the term "bov" or "dv" you would find all of these answers, on a stock audi system you must have 100 % of that waste air recirculated
and for god sakes just listen to onepoint about this... he is a fcucking moderator for a reason...
to reiterate...
100% recirc only
Old 03-15-2007, 10:57 PM
Lopster99's Avatar
I had one of those in my 03 GTI 20th anniversery 1.8T. That is garbage my engine was so screwed up after having it installed for a few months.
Quick Reply: ANY ONE HEAR OF THIS ADJUSTABLE NOISE BOV/ STEALTH FX/ GFB???
