Amplifier Recommendations
OK-
I've given up on getting my rear speakers to run off of my headunit. Does anyone have any recommendations on a decent 4 channel amp that will run the stock speakers for a little while (without blowing them up) but provide enough power when I eventually get around to replacing the door speakers?
I am going to run all four speakers off of the amp.
Thanks.
Thanks.
RE: Amplifier Recommendations
you are going to have to replace the back stock speakers to use an aftermarket amp. Bose stuff does not run on a normal 4 ohms, it uses 2 ohms. All of their audio equipment is meant to work with itself and thats it. You might be able to get it to work if you bridge the amp down to 2 ohms though. I've had good luck with alpine amps and U.S. Amps. I used to run a Crossfire amp also, that was pretty good.
