Sponsored by:
Sponsored by:
Alarm relay/fuse
Old 05-18-2006, 01:59 PM
hazz37's Avatar
Default Alarm relay/fuse
Anyone know where the fuse or relay is for the alarm on a 96 A4
Old 05-18-2006, 03:06 PM
Default RE: Alarm relay/fuse
its located near the standard fuses on plate 2 it has 19 relays and 5 fuses the alarm one is the second from the left on the top #2
Old 05-18-2006, 03:10 PM
onepoint8tee's Avatar
ORIGINAL: avant80@2.6
See... Now what would we do without you?
Old 05-18-2006, 03:12 PM
you could always train black adder 991 but it might take a long time heheheh
Old 05-18-2006, 03:19 PM
hazz37's Avatar
OK got that thanks, but where is the plate located ?, the only one I know of is at the side the dash.
Old 05-18-2006, 03:23 PM
its near plate 1 but up behind it sort of directly above the break peddle behind the dash
Old 05-18-2006, 03:30 PM
You gotta take out the pannel above your knees to get to it easily... i think.
Old 05-18-2006, 03:33 PM
yep I was going to say that but couldn't think of the name for the cover so didn't want to confuse the guy
Old 05-18-2006, 04:37 PM
hazz37's Avatar
Any diagrams out there, that you know of ?
Old 05-18-2006, 05:31 PM
This is the best i can do for showing which relay it is... Other than that, unscrew the screws that are holding the pannel up there, including one or two on the side by the fuse pannel... Dont forget to unattatch your obd port from the other side of the pannel before you pull it out.. Then the relay carrier is up there.
[IMG]local://upfiles/10408/08299D9794D143AC9260CE40237D3F32.jpg[/IMG]
Now that i look at it, that may not be what you are looking for.. i dunno.. i was just excited cuz my bentley is working again..
and its a diagram/pic from a 2000 1.8t, but the relay carrier is the same as 96, i checked.
Quick Reply: Alarm relay/fuse
