Airconditioning
#21
RE: Airconditioning
Connecting air conditioner service station with adapter V.A.G 1785/10 to refrigerant circuit β Unscrew cap from connection with valve -A- (at compressor). β Attach O-ring -B- to connection (8.9 mm; 1.8 mm). β Screw adapter V.A.G 1785/10 -C- to connection -B-. β Install valve opener -D- with appropriate seal in charging hose connection. Note[/align] t The type of valve opener -D- and seals required depends on the charging hose used (specific to manufacturer). t The quick-release coupling adapter is not required for connection on the low-pressure end of Audi vehicles. t Screw charging hose -E- (to air conditioner service station) to adapter - V.A.G 1785/10-. Note[/align] To minimise the amount of air and moisture ingressing into the charging hoses and thus into the refrigerant circuit, the charging hoses should be connected together as illustrated. A- Charging hose to air conditioner service station B- Hand shut-off valve C- Charging hose (short version) with valve opener for connection to adapter -D- D- Adapter - V.A.G 1785/10- E- Charging hose (short version) with quick-release coupling adapter (for vehicles with quick-release coupling adapter on low-pressure end) β Perform planned tests and measurements.
[IMG]local://upfiles/12092/F67F07813F59416986CBE4648FA5F2D2.jpg[/IMG]
[IMG]local://upfiles/12092/B28EA7F4E53044A58EDB4CDC76ED70CF.jpg[/IMG]
#22
RE: Airconditioning
wow, ive read that3 times and I still confused. Lets recap: For my make of audi it needs to be filled at the compressor. However the only way to do that is to use a connector. The part number is V.A.G 1785/10 which I can get commercialy. 2nd, if I can not get to that port on the compressor I have to "remove low-pressure switch for air conditioning system -F73- (jumper contacts in connector for low-pressure switch for air conditioning system -F73-) and screw adapter to this connection βHeating, air conditioning or βAir conditioning" which is part V. A.G 1785/9.
Basicaly what im asking for is a dumbed down version. [sm=dontgetit.gif]
