air conditioning
air conditioning
I have a really silly question. I have a used 2003 Audi A4 3.0Q and I don't know how to turn on the air conditioning (no owner's manual ...). Right now, I have it on "auto" and have turned the temperature all the way down to "Low". I would think that's all I need to do, but the air doesn't seem to get cold. Is there something else I need to do, or is my A/C busted?
Thanks!
Thanks!
RE: air conditioning
Thanks for the responses! I took a look at the car, and for some reason when I hit the "econ" button, it always stays illuminated. I'm assuming this means I have a problem--just wanted to make sure .
Thanks!
Thanks!
What I do so that the air condition doesnt turn on full blast on a hot summer day, is from the "off" state, is simply press the "+" this turns on the air in a semi manual state. If the previous state was full blast from "Auto" then it will turn on full blast, if it does just press "-" until you hit your desired setting (I like mine at one bar or the lowest setting) and thats where it run. Mine does a great job of colling me down at the lowest setting with minimal impact on mpg. And any subsequent starts of the A/C will begin at that low state. The reason I say "semi manual" is becuase if for instance you need to cool down quicker and you raise the power to say 3 or 4 bars then the A/C will cool you down then slowly go back to that lowest setting to keep you comfortable automatically! I don't think doing it that way corresponds to the temperature setting, it seems to be more of a timed thing.
Also I'm sure you've already figured this out but just in case, "Econ" simply means fan mode.
ORIGINAL: samoht
