aiming non HID headlights
RE: aiming non HID headlights
There are 3 bolts that hold the headlight assembly in.
Loosen the 2 that you can easily access from the top.
Once they're loose, adjust to a proper position, hold in place and then tighten the screw back down.
All set.
All set.
You don't have to loosen the headlight adjust the aim. If you look at your headlight, on the top, you'll see a small round white plastic. That is just a cover, remove that and you'll see an allen bolt, you adjust the aim with that. Panda had to show me where that bugger was
