AC blows hot/cold/hot/cold = weird
So my wife's car is at it again. At 168k miles, I suppose things are due to break. So far, we have been able to fix many things ourselves (except the clutch replaced at 130k-ish miles which probably could have lasted another 30k miles). I've searched and came across nothing like this.
My wife's 2001 A4 1.8T AC blows cold / hot / cold / hot air every 20 seconds or so. It's weird. First, I thought the temp sensor at the Ac was dirty - so I vaccuumed all the lint that I saw in it. But of course, it can't be THAT easy. So the problem is still there.
Does anyone have any suggestions?
Many thanks, Armand
Many thanks, Armand
RE: AC blows hot/cold/hot/cold = weird
If there is overpressure in the AC lines/compressor from being over charged, the compressor will go into a safe mode. On/off/on/off like that. Thats what I found out when I accidently over charged mine last year.
ORIGINAL: onepoint8tee
You should get the pressure checked before anything, too much PAG oil in the system, too much refrigerant, not enough, bad a/c switch, and bad compressor could all cause that symptom.
You need to get it diagnosed by someone that is certified to carry out those repairs.
