ABS over-reacting
Old 10-11-2006 | 04:40 PM
jsheridan's Avatar
Default ABS over-reacting
I have a 1998 A4 2.8 and recently the ABS is kicking in any time I brake firmly at low speed turning left, e.g turning into a parking space. I just had the dealership look at it and they simply said that until a light comes on the dashboard, there's nothing they can do!!! Surely there's a more sensible solution??
Old 10-11-2006 | 04:58 PM
aRIf's Avatar
Default RE: ABS over-reacting
I have the same problem but I get used to it.
Old 10-11-2006 | 05:25 PM
onepoint8tee's Avatar
Take the wheels off and spray some brake cleaner on the sensors and make sure that the sensor disks that are pressed into the rotors are gunked up and are completely pressed into the rotors and not coming out. The abs sensor discs get corroded and can deteriorate which can cause you abs to kick on when not needed. Its also possible that your abs control unit is going bad. THey tend to give symptoms before you get a warning light when they start to go bad.
Old 10-12-2006 | 01:02 AM
wood_e's Avatar
You could have a worse case scenario lke me and have to replace your outer CV joint... my ABS ring is chipped but i can live with no ABS.
Old 10-12-2006 | 01:06 AM
AudiCross's Avatar
I hate ABS. sry to be a thread stealer, but does anyone know if it can be disabled?
Old 10-12-2006 | 01:32 AM
wood_e's Avatar
Sure, unplug the computer, clip the wire going to an ABS sensor. Both those methods work, but you'll have dash lights
Old 10-12-2006 | 01:45 AM
AudiCross's Avatar
Okayyy...my dad would $hit bricks, but i REALLY hate ABS. it just sucks all together. and really heats the **** out fo your breaks
Old 10-12-2006 | 02:08 AM
wood_e's Avatar
well, I had to disable mine because i destroyed one of the sensors trying to figure out why the abs was kicking early, and I found my answer...
Old 10-12-2006 | 02:47 AM
AudiCross's Avatar
Lmao ^^^
Old 10-12-2006 | 06:55 AM
B7AudiA4's Avatar
ORIGINAL: wood_e
great! problem solved!
Quick Reply: ABS over-reacting
