about to become broke :(
Old 03-28-2006 | 08:21 PM
swift_A4's Avatar
Default about to become broke :(
Well i just had my 60k service done and they found a ton of stuff wrong.
front lower driver side control arm
brake resevoir needs to be replaced
rear rotors and pads need to be replaced
cam chain is over-rotating and i need a new cam chain kit
valve cover gasket is leaking oil and needs to be replaced.
ugh damn car.
However, i am happy that my 8 panel ceramic clutch kit and lightweight flywheel will be installed in the next couple weeks. I am atleast somewhat happy.
Thanks for letting me rant.
Old 03-28-2006 | 08:24 PM
aRIf's Avatar
Default RE: about to become broke :(
You can do these, no need to pay dealer to do that. See.. you save lots of money already
Just spend a day to do it. That's all. it's fun, trust me
Old 03-28-2006 | 08:25 PM
akaEsCo01's Avatar
you should be able to do the valve cover gasket and brakes on your own...the cam chain sounds like it'll be a job but doable, look into that
Old 03-28-2006 | 08:51 PM
Russ03A4's Avatar
Cam Chain!!???!!
C'mon you experts...that don't sound right at all!!
I've got 122,000 miles on my original rotors, front and back, cut once.
Are the valve covers leaking? You should be able to see.
I think someones trying to rip you off.
Old 03-28-2006 | 09:04 PM
liquidxit2's Avatar
ORIGINAL: Russ03A4
Cam Chain!!???!!
you need new rotors, I garuantee they are out of spec in thinkness. There is a chain on the back of the motor on the cams.
Old 03-28-2006 | 10:10 PM
Russ03A4's Avatar
ORIGINAL: liquidxit2
Yeah, I know, new rotors is on the "short list". But are you saying that Audi rotors shouldn't be cut at all? I haven't measured them nor have I looked up the spec for minimum thickness. The Audi dealer cut them.
Never new about the "chain" but never heard it discussed before on the forum. Learn something new every day.
I have only recently become interested in modding and / or working on this car other than changing the oil.
Old 03-28-2006 | 10:15 PM
Cameron's Avatar
Just curios, you are getting your TB done too, right?
And yeah. aRIF is right, doing work yourself is fun for you and your wallet.
Old 03-28-2006 | 10:38 PM
Russ03A4's Avatar
Yup, this Friday at Renn Art. TB, DV, REVO & new plugs. I'll do the brakes and rotors myself when the weather gets warmer. Don't have a garage.
Old 03-28-2006 | 10:48 PM
99a4audi's Avatar
i need to much stuff done to my car, im scared to see the bill
Old 03-28-2006 | 10:56 PM
Russ03A4's Avatar
ORIGINAL: 99a4audi
I figure that I better start with the things that will hurt me the most if I don't (Timing belt). Last time that alone cost me $1200+ to do at 60k miles. Having Renn Art do it, I'll use the "extra" for the "Extras".
Quick Reply: about to become broke :(
