Sponsored by:
Sponsored by:
A4 acceleration hesitates
Old 03-11-2007, 03:20 AM
generik777's Avatar
Default A4 acceleration hesitates
Hi, So I noticed the other day while accelerating at an average pace ,not to slow and not to fast, that at about 40 mph the car kinda hesitated to accelerate. I pushed the gas a little harder and then it finally kicked up and started speeding up again. This has happened a couple times. Every time it is around the same speed ,close to 40 mph. I either have to give it a little more gas than normal or let off and then hit it again. What could be causing this? Could it possibly be that I just need new spark plugs. Also it only does this some times not always, and only when accelrating at a normal speed. Thanx By the way the car is a 98 audi A4 2.8 quattro.
Old 03-11-2007, 03:29 AM
miked's Avatar
Default RE: A4 acceleration hesitates
is it automatic?
Old 03-11-2007, 03:44 AM
generik777's Avatar
Yes, it is auto.
Old 03-11-2007, 01:43 PM
mlally333's Avatar
Im new to the forum and my a4 had recently done the same thing at bothe 30-40 mph and also at 70-80 mph. At the same time of the hesitation comes a quiet vibrating noise from the dashboard. Does your car also make any sounds while hesitating?
Old 03-11-2007, 04:40 PM
generik777's Avatar
Mine makes no sound. Just hesitates. I havn't experienced it at higher speeds either. I you figure out what it is before I do let me know.
Old 03-11-2007, 05:23 PM
A4nicator's Avatar
bad turbo blown head gasket...... could be several issues OR automatic trans arent as jumpy as manuals when you pop on the gas.
Old 03-11-2007, 06:52 PM
david9999's Avatar
First go to autozone and see if there are any codes stored that didn't trip a CEL. Post them back here.
When is the last time you changed your spark plugs or air filters?
Old 03-11-2007, 09:26 PM
generik777's Avatar
I just purchased the car about 2 months back, so I am not sure when they were changed last. I plan on replacing them all this coming weekend though.
Old 03-11-2007, 09:58 PM
physqoparty's Avatar
My car hesitates slightly when accelerating from about 25-40 if its slightly cold and i do notice a vibration noise coming from eathier the dash or from under the hood when it reaches about 3000 or so RPM. Its not that big of a deal and the hesitation usually goes away once its all warmed up and everything but the vibration pisses me off
Old 03-11-2007, 10:24 PM
AF_guy_ram's Avatar
Timing belt could be why, whens it due for change?
Quick Reply: A4 acceleration hesitates
