A4 acceleration hesitates
Hi, So I noticed the other day while accelerating at an average pace ,not to slow and not to fast, that at about 40 mph the car kinda hesitated to accelerate. I pushed the gas a little harder and then it finally kicked up and started speeding up again. This has happened a couple times. Every time it is around the same speed ,close to 40 mph. I either have to give it a little more gas than normal or let off and then hit it again. What could be causing this? Could it possibly be that I just need new spark plugs. Also it only does this some times not always, and only when accelrating at a normal speed. Thanx By the way the car is a 98 audi A4 2.8 quattro.
RE: A4 acceleration hesitates
Im new to the forum and my a4 had recently done the same thing at bothe 30-40 mph and also at 70-80 mph. At the same time of the hesitation comes a quiet vibrating noise from the dashboard. Does your car also make any sounds while hesitating?
My car hesitates slightly when accelerating from about 25-40 if its slightly cold and i do notice a vibration noise coming from eathier the dash or from under the hood when it reaches about 3000 or so RPM. Its not that big of a deal and the hesitation usually goes away once its all warmed up and everything but the vibration pisses me off
