A4 1.8T - Leaking Coolant
Also referred to as the rear coolant flange.
When looking at the engine from the passenger side take a look behind the motor at the top of the transmission bell housing. If you see a white pinkish crust building up chances are its your rear coolant flange. Many times the o-ring inside the flange goes bad and will cause coolant to leak out.
We have service kits as well as an installation PDF below.
Click HERE to order or for more information
Be sure to check out our -----> Installation PDF <-----
Jason
Bryceaudi
07-31-2007 03:42 AM
