440cc injectors
440cc injectors
is it possible to run bigger injectors before getting new software? i have beeen asking these questions because i plan on upgrading my turbo and i am tryin to piece it together... i would hreatly appreciate any help given
RE: 440cc injectors
You can run bigger injectors but you would need to adjust the fuel pressure to match the larger injectors.
It's better to wait and install the whole turbo upgrade at once. If you are piecing the kit together, just leave the parts in the garage or your closet until your ready.
RE: 440cc injectors
Putting the turbo on before the software will mess up you AF ratio but im not sure how. I think you'll run lean because the bigger turbo would push more air at the same boost level maybe not to sure.
RE: 440cc injectors
well as long as you dont need to boost lower than 6.5lbs to run stoich. just get a AF meter so you can see where your running and tune the boost so your at stoich. and your gonna need an AF meter if your gonna run a MBC anyways so might as well get one now. but if you can put it on and make sure you run stoich and a little rich while accelerating and you should be fine until you get the software
