2000 Stage 3, Quattro
2000 Audi A4 1.8turbo Quattro, grey leather, xenon lights/fogs, 5-spd, Bose sound system, digital dash guages w/trip computer, car also has some aftermarket parts that were all new and added within the last year: APR Exhaust from downpipe back, PES Stage 3 Turbo Kit(Garrett T-28 Turbo)(less than 5,000 miles on turbo/clutch) , SPEC Stage 3 clutch, Greddy Turbo timer, Ottinger 18" wheels. Turbo Kit came with fuel injectors,hoses,air-intake, & exhaust manifold. I just replaced the waste gate regulator, timming belt, serpintine belts, AC-pump belt, Water pump, Thermostat, Brakes, and Tie rod ends. I still have all of the stock parts down to the emblems off the back, such as stock turbo which is still good, air box, exhaust, wheels with new tires, belts so you can see what the condition of the items were in, and that the parts were replaced as preventive maintenece because if you know audi a bad timming belt means bent valves which means no compression. please feel free to call about the car
704-890-4429 cell*
704-664-5680 HM
704-332-4443 Fax (Attn: Sean)
seanmorris@dellmail.com
http://www.cardomain.com/memberpage/599789
RE: 2000 Stage 3, Quattro
The car is dark blue on the outside grey leather inside, I am asking $17,000 mainly because of the just putting the timming,serpintine,ac-pump belts, tie rod ends, brakes, tires, water-pump, and thermostat. this was done because my friend josh's 1998 audi timming belt broke which then caused 9 of the 5valves on each of the heads, and caused no compression in the engine, so i went ahead and did the belt, b/c it was about time for that anyway and since you have to take the bumper and radiator off to change that I figured I might as well do the other stuff. Also I have reciptes to all parts and all of the old parts so you can see the condition of them including my turbo ect. to see they were not in bad shape but preventive maintenance. thanks sean 704-890-4429
zwoelf
01-13-2011 02:24 PM
stage3audi
05-12-2009 09:18 PM
Millionaremoris
12-16-2004 11:12 AM
