2000 A4 rough idle.
2000 A4 rough idle.
Ok the title is deceiving,it's not to much a "rough" idle as it is an annoyingly not smooth idle. When at a complete stop and in drive the car has an annoying ever so slight shake. When I put the car in neutral while stopped it nearly disappears. This also seems to be effected by if the AC is on or off..Off makes it better, On..worse. So obviously while in neutral with no AC it's completely gone.
Also, as a side note, the in dash display has gone out...anyone know of things that could cause that. Its the display that reads if its in D, or R, of N, and tells if car doors are open and if breaks need changing, and things like that. It lights up, but no bueno as far as being able to read anything on it.
justinclarke
11-26-2010 02:29 PM
