2000 a4 1.8tqm making a popping noise
what i take off of when i turn or stop the car makes what i think is a popping noise but it may be a grinding noise can someone help me with this and tell me what this is.
RE: 2000 a4 1.8tqm making a popping noise
Possibly lower control arms or bad ball joints. To test lower control arms with the vehicle on the ground try tightening the lug nuts on front wheels, if they are bad the whole wheel will move you will beable to feel the play. To test ball joint raise vehicle grab front lower part of tire (4 oclock) and try pushing and pulling slightly, play is obvious. Most likely control arms.
I agree control arms.
Possibly CV joints though?
I personally had a slightly bent front sway bar. I guess I ran something over? When the sway bar would turn it would tapping the subframe. Replacing the sway bar and the problem was resolved. Get your car on a lift, check out the movement of your suspension.
