20"s on 2004 A4
20"s on 2004 A4
Hi, I wanna put 20s on my A4 but don't know what width i should go with. This would be pretty much a show car, but i want it to be daily also though. I want it to fit flush witht the body and not stick out. My mechanic recommended me to go with 20 X 8.5s in the back and 20 X 8 in the front. Do you'll think this is the best way to go or wud it be better to go with 20 X 8.5 in the front and 20 X 9 in the back, etc. Please help as I'm gonna order these very soon...it's the final touches on my car.......
RE: 20"s on 2004 A4
You just need to mind the clearance when you turn.. but either way.. you can adjust the offset to make it flush with the fenders. good luck driving with 20s for the daily.. I would personally hate that but that is just me..
RE: 20"s on 2004 A4
My dad's B6 on 19's rides better than my B5 on 16's. I bet a B6 with 20's wouldn't be too bad at all. I barely notice the difference in his car between his 17's and 19's... the steering feels a bit heavier -- that's it.
RE: 20"s on 2004 A4
20's on a b6 is not bad at all... its similar to 19's on a b5... it can definately be done... i think it would look tight..
and i would definately get 20x8 in front... thats where your rubbing is going to occur.
RE: 20"s on 2004 A4
first off, make sure you have a good set of adjustable coilovers..
with that said, 20s look good on a B6. but that's about it IMO.
examples:
Wheels - 20x8.5 Privat Netz +36 with 245/30/20 Falken FK452
MC Hammered's ride:[/align]SDS Invidia 20x8.5[/align][/align](LARGE PICS CAUSE THIS CAR IS LARGE)[/align][/align][/align]
examples:
RE: 20"s on 2004 A4
On the white wagon, is it 20 X 8.5 in the rears too? And i was told the widestg tire i could get for my car would be 225. Whats the widest you can safely go with 20s? I see the white one has 245.......
RE: 20"s on 2004 A4
If you're fitting the proper sized tires on a wheel... the outer dimensions of a 20" wheel/tire should be the same as a 17" tire... so you're no more likely to rub with 20's than with 17's, if you run the right sized tire. Go with 235/30/20 for an OEM size.
morteym
07-29-2012 06:18 AM
ludazena
04-24-2008 12:17 PM
nford
11-16-2006 09:25 PM
