2.8 starting problems?
RE: 2.8 starting problems?
DTC- 16826 - EVAP
emission control system small leak
thats the code that was thrown the last time i checked.. ill check again to see if there is any additional codes
Crank sensors won't always throw a fault code, but they hardly ever fail either.
Replaced hundreds of CTS sensors, and maybe 2 crank sensors, thats a pretty big difference in odds if you ask me.
ORIGINAL: stahly22
well thanks again for the help! tomorrow ill stop by the dealership and see what they say, probably get the cts sensor and hopefully they have one on hand
Well i finally got back home today where theres a warm shop to work in. So i took off the cover and found where the sensor is at,and the sensor that came out had a black housing that plugged into the wiring. But that one that the dealership gave me had a green housing? The sensors look exactly the same, with the same plug and everything so i just put it in, is the one the dealership gave me an updated version or is it actually the wrong one?
ORIGINAL: stahly22
