2.8 40k burns 2 qts of oil between changes
Old 04-13-2006 | 01:02 AM
elphlako's Avatar
Default 2.8 40k burns 2 qts of oil between changes
This is my second oil change since i purchase the car. Firts time the oil warning light came on and i was just a few miles overdue on the oil change. it took 2 qts to top off. Blamed Jiffy Lube's 15 year old kid who did the oil change, since their computer called for 4 qts and the car takes i think 5 3/4 qts. i talked about this to the techs there they advised that they could not find any leaks anywhere looking under the car. Drove of happy thinking it had been a mistake.
Now i am really worried cause i am 1300 from the next oil change and it took 2 qts to top off....The Jiffy Lube guys topped off from free but the problem reamins...no leaks...no noticeable smoke from the exhaust..
Am i using the wrong kind of oil? i have been using synthetic blend 10w30
i cant think of why my engine is burning so much oil
i left a VM with the dealer i bouth the car from and have not heard back..I want to hear from you guys and learn as much as i can before i confronting the dealer.
thanks
Old 04-13-2006 | 01:11 AM
jja2.8's Avatar
Default RE: 2.8 40k burns 2 qts of oil between changes
mobil 1 0w 40 is the preferred oil.
seals are a problem with this engine. do you ever notice the smell of oil? pull one of the plugs and see if its covered in oil.
Old 04-13-2006 | 01:28 AM
fastmayte's Avatar
i got the same prob, i just add a qt like every 2k miles. i use regular 10w30.
Old 07-29-2006 | 05:07 PM
eldrego's Avatar
Member
Hahaha! Dude look at this post...
https://www.audiforums.com/m_302510/tm.htm
Old 07-30-2006 | 06:38 AM
joe4123's Avatar
Member
same prob here buddy mines got 49k and i bought it with 36k, always had that prob., burns about 1/2 a qt. every 1000 miles or so...dunno seems like alot of people have this prob. maybe its normal for this engine?
Old 07-30-2006 | 02:12 PM
eldrego's Avatar
Member
Mine has almost 50K hasn't had an oil change since 46K I just decided to do it over the weekend. Wasn't low.
Old 07-30-2006 | 08:36 PM
Trey25's Avatar
I'd say check for an oil leak somewhere. Mine goes through about 1/3 of a quart between oil changes (4-5k) but I know its because of a valve cover leak. It is normal to lose oil between changes, the stuff evaporates and deteriates.
alexmurphy
10-05-2010 06:00 PM
Stanmarsh
02-09-2010 11:59 PM
beachchair
08-03-2008 07:39 PM
AudimaniaA4
12-19-2007 01:12 AM
grytsenko
11-06-2007 09:04 PM
