1st gear sound..
1st gear sound..
Sorry guys, I know diagnosing sounds over the net is hard...but maybe some of you have heard of/have the same deal. When I'm starting from a stop...put it in first and go, at about 1500 rpm, I hear a slight churning sound for a fraction of a second..(like a quiet teeth grinding). Any idea what this is?
BTW, on the subject of sounds...when I start my car up after it has not been on for a longer period of time (hour +) I hear a sound as if water is flowing through piping...sort of a wish-washing sound. Sounds like its coming towards the rear of the car. No performance issues on either sound, just wondering whats going on. What do you guys think?
RE: 1st gear sound..
the water sound is just gas,, no worries. I think they all do it. I believe it's aiin the return line .
As for the tranny, mine is really tight in the mornin. I'm thinkin of changin my fluid this weekend. But I would guess on Syncros. mine hiss a little bit
the teeth griding this is a common problem ive had the same probelem and some guys on here helped me out. our cars had a ton of protective metal plates everywhere. if these plates move a fraction of an inch they will rub agianst somthing causing a "teeth grinding" sound.
graffix is right on. the flowing water sound is just your gas (you gas tank is shaped like an upside-down 'U' because of the quattro driveline, so it has to draw the fuel from one side of the tank to the other.
the grinding problem sounds to me like a synchro going bad
I am probably just overreacting and being paranoid about the little churn I hear. It really doesnt sound like a grind at all, its more of a slight rub for a fraction of a second. I'm not gonna trip too hard over it right now.
