Sponsored by:
Sponsored by:
1st gear grind
Old 01-02-2007, 04:00 PM
cmk87's Avatar
Default 1st gear grind
i own 98.5 2.8 quattro 5spd n everytime i start off in first there is a horrible grinding noise that doesnt go away till about 3000rpm's in first. no other gears have problems soo if u guys could help out it would b nice thanks.
Old 01-03-2007, 05:22 AM
96audia4's Avatar
Default RE: 1st gear grind
Not sure if it could be the same thing, but my old 2.8 had a chip in the first gear causing a very annoying noise. From inside, it almost sounded like a bad cv joint except really loud. The sound did seem to go away in high rpms though. The car ended up getting totaled before I could fix it. Good luck!
Old 01-03-2007, 11:32 PM
cmk87's Avatar
oo yea that sounds like it would b the problem my mechanic will look at it this week prolly gonna tell me i have a chip in one of the teeth.
Old 01-04-2007, 01:12 AM
dankhound's Avatar
Shouldnt you go to a dentist instead of a mechanic for chipped teeth. Id have to agree thou. Theres probably something wrong with the first gear gearset.
Old 01-04-2007, 06:11 AM
flyboy's Avatar
Sorry to rain on your paraide but the only thing your mechanic is gonna be about to say is, Yeah, its making a noise and we will have to tear it apart to see what it is. If you can live with it, do Its a very expensive propositions. I got suckered into "looking" at mine and ended up costing me $1800 to put it back together. Its fixed now but I would have put that towards a newer car.
Old 01-04-2007, 07:38 AM
that is a very sweet whip flyboy. red looks awesome on that car. what suspension do you have?
Old 01-04-2007, 10:20 AM
david9999's Avatar
My previous post didn't make it. You probably have a worn gear and are looking at having to rebuild the tranny. I'd suggest draining the gear box and putting in new gear oil. This may help delay the inevitible, especially if you have lots or shavings which you are sure to have.
Old 01-04-2007, 02:45 PM
Dj Spiel's Avatar
sounds like a synchro
Old 01-04-2007, 09:47 PM
cmk87's Avatar
well it doesnt matter considering its on the lift right now and i can overnight the part tommorow morning. He's pulling the engine tommorow for clutch work already soo if it nees too b done mite as well get it outta the way while hes gotta eveerything taken apart.
Old 01-04-2007, 10:19 PM
AudiCross's Avatar
ORIGINAL: Dj Spiel
i thought first gear didnt have a synchro
Quick Reply: 1st gear grind
