1999.5 AUDI a4 B5 SWITCHBLADE KEY
RE: 1999.5 AUDI a4 B5 SWITCHBLADE KEY
w3rd!~!!!!!
after 6 months I finally was able to find a right set of directions and reprgrammed my key!!!!
f u audi stealership!!
they wanted 215$ to do it!!!!!!!!!!![:@]
Here is the programming sequence. I still haven't found the clearing sequence.
Programming remote unit
- Switch ignition ON.
- Lock vehicle mechanically at left front door using second key.
- Press "Open" button on first remote unit (key fob) once (to assign memory address to remote unit number one).
Note: The alarm horn will sound briefly each time the "Open" button is pressed to confirm the reception of the signal during this process.
- Wait six seconds after sending last signal, then press "Open" button again.
^ Doors will now unlock (remote unit is now programmed).
- Lock vehicle mechanically again using second key.
- Press "Open" button on second remote unit (key fob) twice at 1 second intervals (to assign memory address to remote unit number two).
- Wait six seconds after sending last signal, then press unlock button again.
^ Doors will now unlock (2nd transmitter is now programmed).
- Repeat procedure for additional remote units (key fobs) to assign memory addresses number 3 and 4 if necessary.
- Switch ignition OFF.
- Check each transmitter for proper function
The following instructions are to reprogram your switchblade key fob.
1. Take a spare key and insert it into the ignition. Turn it one click forward.
2. Roll down your window just in case. Step outside the car, and lock the car with a second key.
3. With your second key fob press the unlock button. The lights should flash.
4. Now lock the car with the key fob, and then unlock it.
5. Remove the key from the lock and the key from the ignition, and try it's function
soccergk
9
05-04-2009 09:12 PM
a4r6
09-13-2008 02:24 AM
