12v source
12v source
i need to hook up my amps remote wire to a 12v source. where is there one in my car. was told on the x75 post(i think thats it) if so, where is it located? and is that a good i dead to do.
98 a4
thanks
98 a4
thanks
RE: 12v source
ok, not sure if u guys know about htis but ill take a shot. i hooked up a amp to the 75x12v source. the amp power green led turned on for like 2 secs and then shut off. i connected to another 12v source and the same thing. does anyone know what the **** im doing wrong?
RE: 12v source
well the ground is connected to the top part of my trunk. i wasnt sure on what part of the battery to hook up to so i hooked up to the part with the small screw. im guessing this is the one to do it, not sure. the remote wire i hooked to the 75x and then i tried it on the remote wire from the back of the head unit. and still the same thing. is my ground maybe bad? maybe i should try another spot?
RE: 12v source
Well the power should be on the + side i believe its even got a red wire connected to it. The ground should be mounted to something more solid like a frame or seatbelt. (be sure to remove all paint before connecting for solid contact to fresh metal)
