12 volt power in the trunk?
Hi all,
Installing an an XM radio tuner and using the adaptor for the changer in the trunk.
I will need a 12v ignition switched and probably a 12v constant.
Whats best to tap into?
I have owned this car less than 24 hours so not too familiar yet.
Thanks!
Thanks!
RE: 12 volt power in the trunk?
if i was putting a boost guage in a vent, (the drivers side) does the wire harness that goes to the back of the vent have a power wire? because it does light up the vent wheel...?
would like to get around running a new wire for a boost guage...
Under the knee bolster is a 75x power post which is "switched power" - best place to get it. Only on when ignition is turned on (or in accessory position).
I ran a wire from that post to my boost gauge in my vent install. I ran all kinds of crap off that 75x post.
