04 A4 1.8t ultra sport 6spd Mod Questions
Just picked up a used A4 Ultra sport. I think it's a great car & would like to improve upon the weak spots. I have a few questions before I move forward with the following mods:
1) Do I need to instal a boost guage with an APR stage 1 or 1 plus chip flash/upgrade?
2) Short shift kits? What do most people like?
3) Want to upgrade the brakes, but don't know what the cost <vs> performance is between a stop tech big brake kit and say upgrading to A8 rotors, better pads, and stainless lines.
4) Not sure if I'll mess with the suspension, but how much can the car be dropped without turning the car in to a filling loosener?
I plan to keep the stock 18's on the car.
Thanks-
Bartlett
Thanks-
Bartlett
RE: 04 A4 1.8t ultra sport 6spd Mod Questions
1) You do no NEED it, but it helps alot it boost leaks/vaccum leaks, and general diagnostics
2) I have a B&M an like it. Also Neuspeed, V&S, I think UUC too.
3) Just do the A8 upgrade, only time I think you would need stoptechs is with substanially more HP.
4) Depends on your budget. Buying some nice h&r or vogtland coilovers will let you adjust ride height and wont be too harsh of a ride
1. it comes in handy but not really needed
2.
3. i would go with the B6/B7 S4 brakes
4. u can find some good coilvoer u can adjust teh dampering and impove the ride quality
2.
Thanks!
How is the reliability of the apr stage 1 plus?
Came from an 03 evo (one of the best braking cars)...how will the A4 braking compare with A8 rotors, stainless lines, and upgraded pads?
I understand the two cars will have different performance traits and am fine with that becuase it is give in take in different areas..... but I would like to have a rough comparison so I know what to expect.
Is is necessary when upgrading coilovers to add a meatier sway bar?
I'm doing all the research now, so that any mods are done once and done right. Sorry for any lack of knowledge.
Thanks again!
Thanks again!
ORIGINAL: Bartlett
Thanks!
Thanks again!
Thanks!
Thanks again!
the EVOs are 4 piston big brakes while tghe A8 is a just a larger One piston brake system
APR stage 1 is a good
jinva
03-18-2012 11:17 PM
hal1993
06-21-2007 12:38 PM
