[Deleted]
Crazy Brake Problem
Master Cylinder could be the problem - maybe pressure is slowly being lost after you have been parked. And after 20 minutes or so it has built back up so that the pedal works more normally.
Just a guess though - I am not all that knowledgable on brakes.
Crazy Brake Problem
Im not that good at brakes either but i had a vacuum line that i had broken when fixing something else so i replaced them with new ones but i got one of the check valves in the wrong way and the brakes acted real funky </P>
There should be a diagram for the vac lines at the top drivers side under the hood try checkin them maybe youl get lucky and itl be somthin stupid(cheap) I dunno</P>
Crazy Brake Problem
Make sure if you have any occurance of a squishy pedal to take it back and have em bleed it again </P>
my last car i had brake work done on it and the next day it felt like i was steppin on a tomato every time i stepped on the brakes. turns out there was a rouge air bubble lodge somewhere We bled them three times and finaly got it out. </P>
$190's not that bad guess it could have been worse huh?</P>
