[[Elim 2871R Dyno Result]]
#36
RE: [[Elim 2871R Dyno Result]]
ORIGINAL: BaconBait
Is that with an upgraded clutch or are still running stock?
Those are some very nice numbers.
#38
NIce job dude. I can't WAIT to get dynoed now. was working on fueling for a few hours today. it feels like i'm makin more power now at 15-16psi that I ever did at 20. those boost #'s kinda blow. I got full boost at 3900 ish when i ran 20psi. you should have full spool at 4k min. lower your FP a bit. you'll get some more torque out of it with less fuel at initial boost. i'm at 11.5 at spool and 12ish at redline. and i'm still gonna lean it out at spool a bit.
If your not pullin any timing, deff lean it out until you pull like 3* then things should be dialed in pretty well and you'll make some better power too!
