$240 and still rough idle and missfires ... advice please
RE: $240 and still rough idle and missfires ... advice please
First I'd go to a local auto parts store to get your codes read if your parts stores do that(they do for free in Seattle). I've heard of temp sensors, oxygen sensors and clogged pcv valves/systems also causing roughness. Those sensors can be checked with multimeters, theoretically I wonder if a shorted out throttle position sensor resistor element could cause a rough idle/misfire? Throttle position sensors can be a quick multimeter test as well.
Ok.. a vaccum leak = LEAN, but I would check for leaks anyway.
I would say its the ICM though, alot of people have had problems with them.
If you have no codes for the MAF, then that should be ok.
New plugs wires - check
MAF/Throttle cleaned - check
Vaccum Lines - ????
ICM - ?????
I would look at those 2 items
Vaccum Lines - ????
ICM - ?????
ORIGINAL: brent07
yeah it will flucuate between 4-7 for an initial 2 sec then smooth out usally and the maybe move a lil bit again every so often if i let it idle ... often idleing will cause the check engine to start to blink ....
Ahh, I didnt read the blinking part... im lazy.. what are you going to do
then yes, it is the ICM.. i will try to find a place to buy it from /part no for you.
hes a pic of it
hes a pic of it
AHhh here you go!
Link to ICM
103.96 Shipped.
Ive seen alot of people buying these for 120,150+
Autohausaz is a good site. I buy from them, quick shipping and good service.
Edit!!! Found LOWER PRICE
2nd ICM Link
98.60 Shipped!!! Saves you like 5 bucks.. but hey! 5 bucks is 5 bucks.. It lists it as 103.79 but all you have to do is put audi06 in the coupon code.. orders over 50$ get free shipping!
Link to ICM
103.96 Shipped.
2nd ICM Link
#20
I just replaced my ICM a few weeks ago...EXACT same problem. Got mine shipped for $80 off ebay...get the HUCO brand for the cheapest. I read good reviews of them on AZ and mine has been working so far. I ordered it on Wednesday, was here on Friday and installed in 3 min.
